Hi guys, I recently got a symmetricom gpsdo, when i power it up the green led flashes once a second and the orange ALM led stays on, after about one hour it locks and the green led goes to 2Hz.
Sending STATus command through serial port replyes with #H/W FAIL ....[EXT] and #OPERATION ALARM...[Antenna]. I don't understand why if it seams to work fine.
GPS antenna and receiver are good because it finds sats and the right coordinates. Do you have any ideas? thanks
The Antenna alarm will be activated if the antenna isn't consuming 'enough' current, or is consuming 'short circuit' current. You can expect this alarm if you aren't using an amplified antenna or maybe with some modern ones that have low power consumption.
What do you get from 'GPS:REF:ANT:CURR?'
You can adjust the thresholds with GPS:REF:ANT:[SHORT|OPEN]:CURR:THR
You can ignore the EXT alarm. These modules were installed in pairs and synchronized, so it's looking for an external reference, but will use the internal one if it is missing.
Thanks for your reply I've tried with these commands but they are not accepted, it responds with "Undefined Header".
@Bad_Driver it looks no components are missing, regarding antenna yes it takes 4mA so this should be the reason.
Finally my symmetricom status:
(This messages are before it locks)
UCCM > SYSTem:STATus?-------------------------------------------------------------------------------
090-0xxxx-xx serial number S3ZBxxxxxx firmware ver 1.0.0.5-01 Ext mode
Reference Status __________________________ Reference Outputs _______________
Ref Ext: [LOS]
TFOM 9 FFOM 3
UCCM-LP Status[OCXO WARMUP]
XX GPS: [not enabled]
ACQUISITION .............................................. [ GPS 1PPS Invalid ]
Tracking: 4 ____ Not Tracking: 0 ________ Time ____________________________
PRN El Az C/N GPS 00:00:58 [?] 06 JAN 1980
10 -- --- -- GPS Invalid: inacc position
18 xx xxx 45 ANT DLY +0.000E+00
20 xx xxx 43 Position ________________________
23 xx xxx 41 MODE Survey: 0% complete
Suspended: poor geometry
INIT LAT N 45:xx:xx.xxx
INIT LON E 12:xx:xx.xxx
INIT HGT +0.00 m (MSL)
UCCM > STATus - UCCM-LP Slot STATE -
1-1. #Now UCCM-LP STATUS --------------- [OCXO Warm]
1-2. #Before UCCM-LP STATUS ------------ [OCXO Warmup]
2-1. #Reference Clock Operation --------- [Not Used]
2-2. #Current Reference Type ------------- [Ext Clock]
2-3. #Current Select Reference ----------- [NOT SELECT]
2-4. #Current Reference Status ----------- [Not Selected]
#GPS STATUS ------------------------------- [Unavailable]
#ALARM STATUS
#H/W FAIL ---------- [ EXT ]
#OPERATION ALARM --- [ Antenna ]
3-1. PLL STATUS ------------------------------- [Enable]
3-2. Current: PLL MODE --------------------- [OFFSET OBSERVATION MODE]
Command Complete
UCCM > POSSTATus-----------------------------------------------------------------------------
1/6/1980 00:15:29
Position : LAT(N 45:xx:xx.xxx) LON(E 12:xx:xx.xxx) H(0.00 m MSL)
Geometry : PDOP(0.0) HDOP(0.0) VDOP(0.0)
Channel Status
num of visible sats > 11
num of sats tracked > 5
------ Receiver Channel State ------
CH 0 > SateID(10) TrackMode(pos avail) SigValue(42)
CH 1 > SateID(15) TrackMode(pos avail) SigValue(36)
CH 2 > SateID(18) TrackMode(pos avail) SigValue(45)
CH 3 > SateID(20) TrackMode(pos avail) SigValue(40)
CH 4 > SateID(23) TrackMode(pos avail) SigValue(41)
CH 5 > SateID(0) TrackMode(code search) SigValue(0)
CH 6 > SateID(0) TrackMode(code search) SigValue(0)
CH 7 > SateID(0) TrackMode(code search) SigValue(0)
CH 8 > SateID(0) TrackMode(code search) SigValue(0)
CH 9 > SateID(0) TrackMode(code search) SigValue(0)
CH 10 > SateID(0) TrackMode(code search) SigValue(0)
CH 11 > SateID(0) TrackMode(code search) SigValue(0)
Rcvr Status(1) :
Antenna Voltage: 4666 mV, Antenna Current: 4 mA
Command Complete
This is after GPS lock:
UCCM > status
1-1. #Now UCCM-LP STATUS --------------- [Master]
1-2. #Before UCCM-LP STATUS ------------ [OCXO Warm]
2-1. #Reference Clock Operation -------- [Not Used]
2-2. #Current Reference Type ----------- [Ext Clock]
2-3. #Current Select Reference --------- [GPS 1PPS]
2-4. #Current Reference Status --------- [Good Accuracy & Stable]
#GPS STATUS ----------------------- [Available]
#ALARM STATUS
3-1. PLL STATUS ------------------------ [Enable]
3-2. Current: PLL MODE ----------------- [NORMAL 2 MODE]
Command Complete
XX Ref Ext :
TFOM 2 FFOM 0
UCCM-LP Status[ACTIVE]
>> GPS: [phase: 1.77e-08]
ACQUISITION ................................................ [ GPS 1PPS Valid ]
Tracking: 5 ____ Not Tracking: 5 ________ Time ____________________________
PRN El Az C/N PRN El Az GPS 17:24:02 16 APR 2021
xx xx xx xx xx xx xx GPS Synchronized to UTC
xx xx xx xx xx xx xx ANT DLY +0.000E+00
xx xx xx xx xx xx xx Position ________________________
xx xx xx xx xx xx xxx MODE Survey: 34.7% complete
AVG LAT N 45:xx:xx.xxx
AVG LON E 12:xx:xx.xxx
AVG HGT +7.16 m (MSL)
ELEV MASK 5 deg
Command Complete
These are available commands after sending question mark:'GPS:REF:ANT:CURR?' is not present
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
*IDN?
ALARm:HARDware?
ALARm:OPERation?
DIAGnostic:OUTPut ON|OFF
OUTPut:ACTive:ENABle
OUTPut:ACTive:DISable
OUTPut:ACTive:HOLDover:DURation:THReshold <seconds>
OUTPut:ACTive:HOLDover:DURation:THReshold?
OUTPut:INACTive
OUTPut:INACTive?
OUTPut:STATe?
SYNChronization:HOLDover:DURation:STATus:THReshold <seconds>
SYSTem:PRESet
SYNChronization:TFOMerit?
LED:GPSLock?
SYNChronization:FFOMerit?
GPS:POSition N or S,<deg>,<min>,<sec>,E or W,<deg>,<min>,<sec>,<height>
GPS:POSition?
GPS:POSition:HOLD:LAST?
GPS:REFerence:ADELay <numeric value>
GPS:REFerence:ADELay?
GPS:SATellite:TRACking:COUNt?
GPS:SATellite:TRACking?
DIAGnostic:ROSCillator:EFControl:RELative?
SYNChronization:TINTerval?
DIAGnostic:LOG:READ:ALL?
DIAGnostic:LOG:CLEar
SYSTem:PON
OUTPut:MODE?
SYSTem:STATus?
SYSTem:COMMunication:SERial1:BAUD 9600|19200|38400|57600
SYSTem:COMMunication:SERial1:BAUD?
SYSTem:COMMunication:SERial1:PRESet
SYSTem:COMMunication:SERial2:BAUD 9600|19200|38400|57600
SYSTem:COMMunication:SERial2:BAUD?
SYSTem:COMMunication:SERial2:PRESet
OUTPut:STANby:THReshold <seconds>
changeSN
SYNChronization:REFerence:ENABLE EXT|GPS
SYNChronization:REFerence:DISABLE EXT|GPS
SYNChronization:REFerence:ENABLE?
STATus
POSSTATus
TOD EN|DI
TIME:STRing?
REFerence:TYPE GPS|EXT
REFerence:TYPE?
PULLINRANGE 0|1|2|...|254|255
PULLINRANGE?
FREErun EN|DI
FREErun?
DIAGnostic:LOOP?
DIAGnostic:ROSCillator:EFControl:DATA GPS|<value>
DIAGnostic:ROSCillator:EFControl:DATA?
OUTPut:TP:SELection PP1S|PP2S
OUTPut:TP:SELection?
GPSystem:SATellite:TRACking:EMANgle <degrees>
GPSystem:SATellite:TRACking:EMANgle?
DIAGnostic:TCODe:STATus:AMASk
DIAGnostic:TCODe:STATus:OMASk
DIAGnostic:TCODe:ERRor:AMASk
DIAGnostic:TCODe:ERRor:OMASk
DIAGnostic:HOLDover:DELay
DIAGnostic:HOLDover:DELay?
GPS:SATellite:TRACking:IGNore <PRN>, ...,<PRN>
GPS:SATellite:TRACking:IGNore?
GPS:SATellite:TRACking:INCLude <PRN>, ...,<PRN>
GPS:SATellite:TRACking:INCLude?
GPS:SATellite:TRACking:<select>:ALL
SYNChronization:INPut:PPS:DELay <numeric_value>
SYNChronization:INPut:PPS:DELay?
DIAGnostic:ANTenna:CFEED <ON|OFF>
DIAGnostic:ANTenna:CFEED?
