Hi All,
I purchased one of these GPSDO's close to a year ago. At the tie I bought it, I tried it out and it worked fine. A week or so later, I acquired a Spectracom Ageless Master Oscillator and have used that to this point to supply reference for my counter and other equipment.
This week, I decided to hook it up again and it is non-functioning. I push the RST button (I assume it is a reset button) and it merely reboots like it used to do only no 10 MHz out or 1 PPS. I hit the other reset button labeled MACI and the 2 upper green LEDs flash back and forth. In either case, I get no 10 MHZ or 1 pps.
Has anyone else encountered this? I looked back a number of pages on this thread, but saw no mention of this unless I accidentally overlooked it. It is too late to ask the seller to make good on it. I should have ran it more than a few minutes when I initially bought it.
Bill
K1FPV
