OK... this is completely over the top but this is the dialog I see between the Renesas and the Furuno...
I have swapped $ for % to indicate a message from Furuno to Renesas...
%GPGGA,000002,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000002,01,01,2002,+00,00
%GPGSV,1,1,00
%GPVTG,,T,,M,,N,,K,N
%PFEC,GPtps,020101000002,1,0,1,000000000000,00,00,000000000000,1147,172802
%GPGGA,000003,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000003,01,01,2002,+00,00
%GPGSV,1,1,00
%PFEC,GPtps,020101000003,1,0,1,000000000000,00,00,000000000000,1147,172803
%GPGGA,000004,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000004,01,01,2002,+00,00
%GPGSV,1,1,00
%PFEC,GPtps,020101000004,1,0,1,000000000000,00,00,000000000000,1147,172804
%GPGGA,000005,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000005,01,01,2002,+00,00
%GPGSV,1,1,00
%PFEC,GPtps,020101000005,1,0,1,000000000000,00,00,000000000000,1147,172805
$PFEC,GPint,GSV00
%GPGGA,000006,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000006,01,01,2002,+00,00
$PFEC,GPint,VT|%GPGSV,1,1,00
%GVTG,,T,,M,,N,,K,N
%PFEC,GPtps,020101000006,1,0,1,000000000000,00,00,000000000000,1147,172806
$PFEC,GPint,GSV00
%GPGGA,000007,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000007,01,01,2002,+00,00
%GPGSV,1,1,00
%PFEC,GPtps,020101000007,1,0,1,000000000000,00,00,000000000000,1147,172807
$PFEC,GPint,GSV00
%GPGGA,000008,3444.0000,N,13521.0000,E,0,00,00.00,000000.0,M,0036.7,M,,
%GPZDA,000008,01,01,2002,+00,00
$PFEC,GPint,ZD|%GPGSV,1,1,00
%GVTG,,T,,M,,N,,K,N
%PFEC,GPtps,020101000008,1,0,1,000000000000,00,00,000000000000,1147,172808
$PFEC,GPint,GSV00
So at startup the Furuno sends quite a few messages, unsolicited. Then it gets a series of commands from the Renesas and then after a while things start generally interleaving and getting more confusing!
If you look at Section 1.5 in the receiver software spec you will see values like... "N34deg.44.0000 min. E135deg.21.0000 min." as default values following restart without battery back-up, so
isn't that unexpected and confirms the the Furuno sends first.
Share and Enjoy
