As mentioned before last week my SAMSUNG UCCM arrived.
Even though my prepared PSU in the dedicated enclosure delivers only 5.2 Volts (on the fuse on the board I measure 5.00 volts)
I gave it a try - and voila! - it works from beginning! The log wasn't erased, first entry is from 2016, last from 2018, seems to be
an newer board. First location is a radio tower on an oil field in Elk Hills Elementary in CA, USA, not far away from Bakersfield. One year later it was
in a small house under 3 high voltage lines in South San Jose, CA, USA at the end of a golf course.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Long way for this board, travelled several times around the world!
It found the first satellites after some seconds, locked after 40 min and after one hour I got my first TFOM=1, what I never have seen
with the SYMMETRICOM UCCM. Syk view isn't that good since my antenna is nearby the window and the roof is covered with a lot of snow these days.
Much better than the Sym-UCCM!
Attached a photo of my not yet accomplished housing - I'm awaiting some nylon spacers.
On the right side my PSU - from an old SAMSUNG-monitor, I removed the high voltage (700V) part.
In the middle a FT232- USB-interface and a UART-V24 level shifting board. Above the breakout board I found @ Aliexpress as well.
Left the SAMSUNG UCCM. I changed the delivered short coax cables with BNC-cables.
I think the 50€ @ ALiexpress for the board has been a good investment!
