hi there,
Last week I received a Symmetricom UCCM module, sans OCXO. Carefully inspected the module, it does not appear to have any damaged/lost components. Just had to remount C1, close to the PPS connector.
I have tried to marry it with 3 different OCXO types:
- Murata-Erie OC2501DT
- Bliley NV47A1282
- Trimble 34310T
All powered according to their specs, so 12V or 5V. The Trimble is now connected, and powered directly from a 12V DC supply. The 5-12V boost converter does not seem to like the Trimble, too much whining and drawing 2A from the 5V supply. Anyway, this should work. I repurposed a Sarantel helix antenna which I took out of a handheld GPS years back, adding a 5V-3V LDO to it. The antenna sits now on the side of the roof, just outside the window of my shack, which roughly faces South. Position hold mode is what we need, so that all appears OK to me.
OK.. Sofar the stage.
Now the question: looking at the attached Heather screenshot, I wonder out the sawtooth purple PPS trace. On the command line the Status of the UCCM shows me "Assessing Ref". I have been powered on now for say 18 hours or so.
Is this the UCCM trying to figure out if the GPS derived PPS is stable enough for meaningful reference to the PLL? The green line in the graph is not moving in the slightest.
When I had the Bliley OCXO connected the green line was more like a block pulse (not good I think). See the 2nd screenshot.
Do note this is new territory for me, so please be gentle
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
Wilko
