I always thought that I've seen enough different types of potentiometers until I bought this one, just received it recently, almost lost my jaw when I saw and held it in my palm, I wasn't expecting it will be this huge.
Its the vintage Beckman Helipot 10K, 15 watt rated, 15 turns and with 0.02% linearity, also it looks like its designed to be hooked up with servo motor since the shaft is using a ball bearing and its made by Fafnir in usa, I guess it must be > 30 years old.
To other experienced fellows, just curious, apart from very good linearity, are there any other special care or treatment should I aware of since this is quite old piece of equipment ? From appearance, I believe its nos and the gold plated terminals are never soldered. I will let the pictures tell the tale since I'm speechless bout it's size.
Ok, how big is big ? The one 5 watt in the middle is already considered quite a big pot isn't it ? Wait a minute, no, the pot in this pic is not the one I'm talking about, wait till you see the 2nd photo.
A picture worth lots of words.
Its even fatter than a soda can.
Other more details shots with ruler to give you the idea of the size are at below thumb nail sized pics.
