Author Topic: A digital-analog-digital nixie clock  (Read 1884 times)
Offline ynfoTopic starter
« on: March 07, 2016, 03:34:27 pm »
Yes, a pretentious title for yet another Nixie clock project  ;)
However this is a bit different from other projects in that I'm using an un-modified 1970's multimeter. The idea is to display a voltage equivalent to the time, so e.g. 12:45 becomes 12.45V. The block diagram is RTC -> Arduino -> DAC ->Multi-meter where the arduino reads the time, calculates the required voltage and sends it to the DAC.
I was concerned about the last minute digit flickering or being off by one and showing silly times like "12:60" and although this does happen occasionally it's not a problem in real world use. And the clock is still usable as a multimeter!
I haven't seen this approach used before so I thought I'd share.
More details/pictures at http://ynformatics.com/2016/nixie-voltmeter-clock/
« Last Edit: March 07, 2016, 03:36:00 pm by ynfo »
Offline edavid
Re: A digital-analog-digital nixie clock
« Reply #1 on: March 07, 2016, 04:47:31 pm »
Nice!  You can do the same thing with a frequency counter.
Offline rrinker
« Reply #2 on: March 07, 2016, 05:01:05 pm »
Neat idea. I want that meter.
