Author Topic: AC  (Read 456 times)
Offline JacktronTopic starter
AC
« on: September 06, 2024, 11:51:29 pm »
I am trying to create a circuit that can generates AC magnetic fields in two pairs of helmholtz coils. How can I best do this and could you include schematics from a place like falstad?
« Last Edit: September 06, 2024, 11:57:37 pm by Jacktron »
Offline IanB
Re: AC
« Reply #1 on: September 06, 2024, 11:54:43 pm »
You get a 120 V AC solenoid and connect it to the mains. Job done.
If that's not the answer you want, you might need to give just a tiny bit more information?
Re: AC
« Reply #2 on: September 07, 2024, 12:03:16 am »
I added a little more info: I have two pairs of helmholtz coils that I want to generate ac magnetic fields of for example 0.01 T
Offline PGPG
Re: AC
« Reply #3 on: September 07, 2024, 12:42:28 am »
Without knowing anything about these 4 coils (I understand two pairs as four) the only what can be said is to supply them with adequate current.
You can use AC mains as source and trafo (auto-trafo) or resistor to reduce the voltage/current applied to them.
Online Smokey
  • Not An Expert
Re: AC
« Reply #4 on: September 07, 2024, 12:47:26 am »
... DC ....
Your move..
Re: AC
« Reply #5 on: September 07, 2024, 12:48:40 am »
one pair with a radius of 2 cm and another with 1 cm
Re: AC
« Reply #6 on: September 07, 2024, 12:49:32 am »
I am trying to create an ac field
Offline Andy Chee
Re: AC
« Reply #7 on: September 07, 2024, 01:03:26 am »
what AC frequency?
what inductance coils?
what thickness copper wire?
Re: AC
« Reply #8 on: September 07, 2024, 01:08:27 am »
10 hertz
20 coils
.1 cm wire
The following users thanked this post: boB
Offline Andy Chee
Re: AC
« Reply #9 on: September 07, 2024, 01:31:47 am »
what is your input voltage? is it a battery? what kind of battery?  or is it mains powered?
Can you give a wider picture of your project?  Is this a hydrogen generator?
Re: AC
« Reply #10 on: September 07, 2024, 01:39:21 am »
i have 9v dc battery
