Author Topic: ACS712 and ESP8266  (Read 4264 times)
Offline JacquesBBBTopic starter
ACS712 and ESP8266
« on: September 08, 2016, 09:15:32 am »
Hi All,
I  want to use an ACS712 current sensor to verify that a device ( heater) is turned on with a nodemcu (ESP8266).
It will be 1.5 kw so 6.5 A on 230 V. I will use 20 A ACS712 that is 100mV/A.
The output of the ACS712 will thus be 2.5 V + 0.65V sinewave.
This would be easy on an arduino, but the ADC pin of the ESP8266, from what I understand is only 1V range.
I thus want to  transform the output signal in a plain HIGH state for the ESP8266, and not
use the ADC.  I just want to know if it is ON or OFF.
After  searching a little bit, I came with the following design. The final output is PR5.
I made the simulation under multisim.  A is in ON (2.5 V + 0.65V sine input) , B is OFF (2.5 V input).
Please comment and criticise.
« Last Edit: September 09, 2016, 12:26:06 pm by JacquesBBB »
