Indeed, I forgot that the console also measures inside temperature and humidity...
SeanB the board is from the console that displays all the weather data and is inside the
house, so the little blue chip doesn't look like to be a light/cloud sensor but even if it is a
humidity sensor why does it need to have 12 soldered pins!?!
The little red part could be the temperature sensor.
I applied some heat with a hair dryer... and its resistance went down from 10Kohm to 4Kohm
and it was raising again as the unit cooled down. When the temperature reached again the
initial value, its resistance was exactly 10Kohms again.
electronupdate I agree. The problem should be somewhere near the CC1021 chip.
The problem is that when you power up the console the error message is the first think you find.
Then you go into a menu that lets you choose which transmitting station to use and several
other parameters and when you go out of this mode, then you get the on/off signal from the
crystal. It also displays the letter R which in the manual it is stated that console waits to
re-establish a connection.
The Davis technician said that "there is a radio calibration process that occurs during
startup. If the calibration process cannot complete itself it triggers the PLL error",
so the error happens before any RF synchronization attempt is made!I've probed pin 9 on the chip and it has a
2.99 voltage. What does this mean?
Locked or Unlocked? The chip works with 3V. Does this mean that the pin is high,
and therefore actually PLL Locked?
There is another small detail.. in the datasheet of CC1021.
"There is a finite possibility that the PLL self calibration will fail. The calibration routine in the
source code should include a loop so that the PLL is recalibrated until PLL lock is achieved if
the PLL does not lock the first time. Refer to CC1021 Errata Note 002."Below is the Errata Note they are talking about: (Note 002)
http://www.ti.com/lit/er/swrz007/swrz007.pdfMaybe someone can interpret the above information and suggest a testing method.
It looks like that Davis did not do their homework, because more people are having the same
problem.
I still don't know where this "source code" mentioned above, is stored and how you can access it.
