I've just tried a new 10uF on top of C11, but nothing happened.
Same PLL error...
There is a tiny tiny capacitor though labeled C28, that has a
9 Ohms ESR!It measures exactly 3nF. Its right next to the crystal on the left side in the photo.
Isn't that too high? Could it be that the 9 Ohms is a false reading?
I have contacted Davis support with all the details and they've just replied to me saying that they do not
repair the faulty consoles. They just replace the boards. (I hate that habbit of the 21st century... )
He also said that "
sometimes it is the crystal Y51 (14.7) but it could be the radio chip or the CPU"
Now, it does not seem likely to me that it is either the CPU or the radio chip. The weather
station after the PLL error, works as usual and responds to every command and function.
The PPL error is reported correctly as well. Its not a false positive.
I have also asked him if they have taken into account Note 002 of the CC1021 Errata and
programmed the firmware correctly in order to avoid PLL lock errors that are inherent to
the CC1021 chip! If he replies that they have, then the only thing that remains is to remove
the crystal and test it.
Don't you agree?
