Author Topic: 9 volt low current power supply circuit wanted.  (Read 1224 times)
Offline Jim0000Topic starter
« on: May 03, 2019, 01:59:01 am »
I am looking for a circuit for a 240v mains supplied power supply that will deliver around 9 volts at 50ma max.
The requirements are that this device be a small as possible.
What it comes down to, is the question of finding a very small 240/12 volt transformer. I am able to design a full bridge rectifier, zender diode, cap and resistor
regulated system.
If someone can direct me to a source I would appreciate it.
Jim.
Online MarkF
Re: 9 volt low current power supply circuit wanted.
« Reply #1 on: May 03, 2019, 02:08:08 am »
I saw these for some else yesterday.  I do not know how noisy these might.  They seem simple enough with a 12V Wall Wart.  They say they accept either AC or DC inputs.
https://www.ebay.com/itm/AC-DC-Power-Supply-Buck-Converter-Step-Down-Module-3-3V-5V-9V-12V-15V-24V-36V-US/122832954547?hash=item1c996a24b3:m:mNop_RHwBUxr99MJ7MTU6Cg
The following users thanked this post: Jim0000
« Reply #2 on: May 03, 2019, 05:21:12 am »
That would most likely do the job nicely. Is that a LM7809 regulator? I assume that it is.
Thanks!
Offline Jwillis
« Reply #3 on: May 03, 2019, 08:43:14 am »
Both examples from MarkF and blueskull are buck convertors .They are in a class of switch mode power supply (SMPS). The LM7809 is a linear regulator that would require a much larger package to facilitate a transformer and rectifier.
But I'm sure either would be fine for your purposes.
Offline mariush
« Reply #4 on: May 03, 2019, 09:33:30 am »
if you want to fully avoid switching power supplies, tme.eu sells some tiny pcb mounted transformers
Here's a link with 7.5v..12v ac , 0.5va.. 2.5va : long link
In theory a 7.5v transformer could be used if you don't need a stable 9v, like for ex. you just want a 9v battery replacement.
you use a bridge rectifier which converts 7.5v ac to dc with peak of 7.5v  x 1.414 - 2 diode drops ... so ~10.5v - 2 x 04..0.6v (low drop at 50mA) so around 8.v..9.5v
You'd only need a capacitor to smooth the output .. let's say a 1000uF 16v cap would be enough ... c= i/[2 x Fac x (Vpeak-Vmin)] = 0.05/2x50x(9.5v-9v) =0.05/100x0.5 = 0.001 Farads
Problem is when your circuit only consumes 5-10mA instead of 50mA.. at such low voltage and current transformers output much higher voltage at low load.. ex at 5mA a 7.5v ac transf. may output up to 25% more, let's say 9v ac.. which rectified could mean 10..11v dc
So it may be better to go with 9v AC, rectify with bridge rectifier to ~11v, use a smaller electrolytic to guarantee a minimum of let's say 9.5v and then use a LDO to get 9v
A 7809 or 1117 will need ~0.7v even at 50mA but there are ldos with 100..300mV drop at low currents.
ex.
1.69$ each : 12v 1.9VA (158mA)  32.5 x 27.5 x 23.8mm  81g : https://www.tme.eu/en/details/bvei3032032/pcb-transformers/hahn/bv-ei-303-2032/
1.95$ 12v 1.5va (125mA) more sqare-ish and taller 70g : https://www.tme.eu/en/details/tez1.5_d_12v/pcb-transformers/breve-tufvassons/tez1-5-d230-12v/
1.95$ 9v 1.5va (166ma) same size/weight : https://www.tme.eu/en/details/tez1.5_d_9v/pcb-transformers/breve-tufvassons/tez1-5-d230-9v/
2.00$ : 9v 1.8va (200mA) : https://www.tme.eu/en/details/bvei3022001/pcb-transformers/hahn/bv-ei-302-2001/
for ldo theres plenty
mic5225 : https://www.digikey.com/product-detail/en/microchip-technology/MIC5225YM5-TR/576-2998-1-ND/1834780
ap2204k : https://www.digikey.com/product-detail/en/diodes-incorporated/AP2204K-ADJTRG1/AP2204K-ADJTRG1DICT-ND/4505290
lp2951 (100mA max) : https://www.digikey.com/product-detail/en/on-semiconductor/LP2951CDR2G/LP2951CDR2GOSCT-ND/2120680
etc...
Offline ebastler
« Reply #5 on: May 03, 2019, 11:04:30 am »
@Jim0000: Is this for tinkering, or for use in a product? What are the safety and compliance needs -- CE, UL etc.?
Offline Tek Tech
« Reply #6 on: May 04, 2019, 05:43:30 am »
@ Jim0000, you can also use a super small and simple circuit of a series capacitor, bridge rectifier and a Zener under two conditions: (1) Your project is drawing a relatively constant current or a small current in relation to the Zener's max current, and (2) It does not need to be isolated from the mains. (If your project does need to be isolated from the mains then a small transformer or a switched mode PS are the options.)
You can use one of the online calculators to estimate the value of the series cap in circuit below. Note that 50Hz and 60Hz mains will require slightly different C values. E.g. a 470 uF cap will have 6.8 kOhm reactance at 50 Hz - which will allow you to draw up to 30 mA. A 680 uF will let you draw about 48 mA, which is very close to what you need. 820 uF will get you up to 57 mA @50 Hz, etc.
http://www.sengpielaudio.com/calculator-RC.htm
« Last Edit: May 04, 2019, 01:01:40 pm by Tek Tech »
