Author Topic: Capacitance multiplier - do I need to protect the NPN using a diode?  (Read 2181 times)
Offline humbug11Topic starter
I'm experimenting with using a capacitance multiplier as a noise filter. It seems to work rather well, but one thing that I'm not sure about is if it is necessary to protect the NPN transistor from negative Emitter-Collector voltages. According to the DS, the maximum Emitter-Base voltage is 6V, which will be exceeded when removing the battery or if there is a large negative "spike" on "+Batt". However, only very little current can flow in these situations, as the total capacitance on the "V_BATT_FILT" net is in the order of 10uF.
Will removing the battery or negative spikes damage the NPN transistor over time and is it necessary to protect it using a diode? If so, what diode would be best? Ideally, it should start conducting at a few volts in forward direction and the reverse voltage should be in the order of 40V.
Offline Paul Price
Re: Capacitance multiplier - do I need to protect the NPN using a diode?
« Reply #1 on: March 01, 2018, 11:12:43 pm »
Adding a series >40V rated schottky diode to the +Bat input would protect this circuit from negative spikes and add only a minimal voltage drop. Anode of diode to +BAT
Online langwadt
« Reply #2 on: March 02, 2018, 12:17:24 am »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: September 08, 2020, 06:52:11 pm by Simon »
Offline iMo
  • Country: bt
« Reply #3 on: March 02, 2018, 01:14:13 am »
This seems to protect the npn transistor best.
The diodes and transistor types an example only.
Provided as-is, no warranties of any kind are provided :)
« Last Edit: March 02, 2018, 01:16:39 am by imo »
Offline David Hess
  • DavidH
« Reply #4 on: March 02, 2018, 12:00:45 pm »
The capacitance you are multiplying can only discharge through the base-collector junction if the input voltage is removed which has the characteristics of a diode with a rating of the Ic (collector current) and Vcbo (collector-base breakdown voltage) of the transistor so it is very unlikely to be damaged.  Collector-base junctions of transistors are sometimes used as high performance power diodes.
The base-emitter junction is a different matter and is often protected by an anti-parallel diode between the base and emitter leads or base and collector leads.  In a power transistor the base-emitter junction can actually sustain considerable reverse breakdown current without affecting the circuit however the high power resulting from the relatively high breakdown voltage can lead to thermal damage.
