Author Topic: 74lsXXX vs 74XXX chip famies?  (Read 667 times)
jfiresto and 3 Guests are viewing this topic.
Offline rwgast_lowlevellogicdesinTopic starter
    • LowLevel-LogicDesign
« on: September 01, 2024, 11:25:09 pm »
I bought a bunch of dip tubes and plugs, so ive been sorting and labeling my massive collection of chips.. how fun. Anyways i have a lot of old parts, while sorting my logic gates i found some chips like this
2358151-0
Im assuming this is just a 74xx121, but is it the same as a 74ls121? From a quick search its TTL, but can i count on 74 being the same speed and pinout as 74ls?
Online wraper
  • Country: lv
Re: 74lsXXX vs 74XXX chip famies?
« Reply #1 on: September 01, 2024, 11:30:49 pm »
Logically it's the same as 74LS, it's TTL too but electrically it isn't the same. Much higher current consumption, has higher input current.
Online Kim Christensen
« Reply #2 on: September 01, 2024, 11:46:53 pm »
The 74LSxx is faster and draws less power than the plain old 74xx series. Not much use for these today except for repairing vintage equipment and nostalgia.
Good summary on Wiki.
Online tooki
« Reply #3 on: September 01, 2024, 11:50:40 pm »
(Attachment Link)
Pinout: very likely yes. (I’ve heard there are a few exceptions, but normally they are pinout-identical.)
Speed: absolutely not. That varies by logic family.
See https://www.ti.com/lit/sg/sdyu001ab/sdyu001ab.pdf
Online Zero999
  • 0999
« Reply #4 on: Yesterday at 08:57:15 am »
I wouldn't bother stocking plain old 74 or even 74LS. The exception being the 74LS06, which can drive 30V loads up to 40mA. My advice is sell them on, unless you have a specific need for them.
Offline RoGeorge
« Reply #5 on: Yesterday at 09:10:25 am »
I would take that as an equivalent for SN74121, TTL monostable.  N stands for Normal TTL, so not LS TTL.
https://www.ti.com/lit/ds/symlink/sn74121.pdf
A brief list with main characteristics for each logic family by TI:
Logic Guide https://www.ti.com/lit/sg/sdyu001ab/sdyu001ab.pdf
Offline David Hess
  • DavidH
« Reply #6 on: Yesterday at 11:29:02 am »
Functionally the 74121 would be the same as a 74LS121, and usually TTL and LS TTL may be interchanged.  However I am not sure the 74LS121 ever existed because it is not listed in The TTL Data Book, although the 74L121 is.
In general, LS TTL is the same speed as TTL, but at like 1/5th the power level.  Usually they are interchangeable, but not always.  LS TTL and TTL have different fan-in and fan-out requirements.
Online coppice
« Reply #7 on: Yesterday at 11:36:44 am »
LS is usually in the same ballpark for speed as a similar non LS part. LS went for similar speed, lower power. S went for similar power, higher speed. Sometimes they went overboard with the S part, and it takes considerably more power.
Online tooki
« Reply #8 on: Yesterday at 02:35:00 pm »
No, N does not stand for "Normal TTL"!  :palm:
Original TTL chips simply have no letters between the 74 and the rest of the number (e.g. 74xxx). Every other logic family inserts letters there (e.g. 74LSxxx).
The N on a 74121N means plastic DIP package, in TI logic chips.
The SN prefix is TI's prefix for standard logic, and is short for "semiconductor network". (Source: https://archive.org/details/bitsavers_tiTexasInsSeriesMorrisDesigningWithTTLIntegratedCi_11927910/page/n25/mode/2up )
Online TimFox
« Reply #9 on: Yesterday at 04:09:01 pm »
Comparing simpler logic gates, such as the 7400 and 74LS00 quad NAND gates:
In the older 7400 "standard" TTL circuit, the input device is a multiple-emitter NPN transistor (hence the name transistor-transistor logic).
There were also 74L00 (low-power variant of 7400) and 74H00 (high-power faster variant) true TTL devices.
The 74S00 high-speed gate uses NPN transistors with Schottky junctions to reduce stored-charge switching delays, including the input multiple-emitter NPN stage.
The later 74LS00 has the same pinout and function, but the input stage is actually DTL (diode-transistor logic) using Schottky diodes at the input, and voltage levels compatible with the 7400 but different current levels.
The internal NPN transistors have Schottky junctions to reduce stored charge.
Other variations include the 74F00 from Fairchild that had different trade-offs between speed and power.
When connecting one series to another, there is usually no problem with the voltage levels for logic 1 and 0, but care must be taken that the total current drawn by the loads (especially in logic 0 low state) must be within the spec for the driver in its low state, at the specified logic voltage level.  For example, a 7400 can drive more 74LS00s (in parallel) than a 74LS00 can drive 7400s.
Online coppice
« Reply #10 on: Yesterday at 04:20:01 pm »
You missed H, ALS and AS if you want to list the full set.
Online TimFox
« Reply #11 on: Yesterday at 04:30:57 pm »
I mentioned "H", merely a high-current variation on 7400.
I did not include the later CMOS series that were pin-compatible with the 7400 TTL series but have different electrical characteristics that can be compatible with 7400.
Offline David Hess
  • DavidH
« Reply #12 on: Yesterday at 04:32:54 pm »
Fairchild F TTL was FAST or Fast Advanced Schottky TTL, with similar performance to AS TTL or Advanced Schottky TTL.
Fast Advanced Schottky TTL had amazing performance which was limited by DIP packages and even small outline packages because the corner connections of ground and power had too much inductance.  It had about the power requirements of LS, but was faster than schottky TTL, and had excellent drive.  Unfortunately not many functions were transferred and it never became as popular as LS, which it could almost always replace.
Online coppice
« Reply #13 on: Yesterday at 04:49:26 pm »
Although F, AS and ALS never existed as full lines of parts, like the earlier families, they did make a big difference. Vendors focussed on the parts customers said were holding them back, like latches and buffers, and they sold well. Not every part in a system needs to work at blistering speed.
There was a push to produce variants with the power pins in better places. I'm not sure if many of those actually went out the door.
Offline David Hess
  • DavidH
« Reply #14 on: Yesterday at 06:17:42 pm »
Lower inductance power and ground pin placement is more important for CMOS where the rise and fall times are faster.  Bipolar logic families had an advantage with slower slew rates for the same propagation delay, which I suspect was because at a given current, bipolar transistors have higher transconductance than MOSFETs.
Center aligned power and ground became available after FAST TTL for both CMOS and bipolar, but I do not remember if FAST or AS ever got that.
Offline CaptDon
  • Country: is
« Reply #15 on: Today at 03:16:15 pm »
What a laugh "N stands for normal", where in the hell did he get that from??? The reply N stands for the packaging type is correct. As for the 'LS' verses non-LS and L versions of the one shot devices there is a huge difference in the timing component values needed for a specific pulse width. This is true of the 74121, 122 and 123 devices. There is also a difference in the minimum and maximum pulse widths as well as the high and low value limits of the timing components themselves. 74XXX and 74LSXXX parts are valuable for experimenting and breadboarding. the 74ACTXXX series is so incredibly fast that they seldom work correctly on a breadboard. You will find these older parts still sell very well on Ebay, particularly when they are New Old Stock in the sleeves.
Offline CaptDon
  • Country: is
« Reply #16 on: Today at 03:27:49 pm »
The militarized 5400 54XX series had a lot of parts with 'centered' power pins making them hard to find for repairs today. Although the function of the chip 7400 vs. 5400, 7410 vs. 5410 etc. were usually the same the pinout was often different and the specs were different. One example I seem to recall is a 7400 was spec'd 4.75 to 5.25 volts VCC where the 5400 stuff was 4.5 to 5.5 volts VCC.
Online coppice
« Reply #17 on: Today at 04:40:19 pm »
The 5400 and the related military DIP parts were pin compatible with the 74xx DIP parts. We used the 74xx parts for all our military development, and eventually the military parts went into the final qualification testing prototypes and production units. Some people confuse 54xx with military. They aren't the same. 74xx was commercial temperature range. 64xx was industrial temperature range, although you rarely saw them. 54xx was military temperature range, normally in ceramic packages. As you noted, some of the timings and other parameters were different for the various versions, but if your design worked with 74xx parts it would generally be OK with the 54xx parts.Above the 54xx parts were the actual military parts, where each individual part went through extensive qualification, and cost a fortune. They were distinguished by the alpha part of the device name. The 54xx, 64xx, and 74xx naming is similar to the 1xx, 2xx and 3xx nomenclature that National and others used for similar analogue parts in different temperature ranges.
Things like the flat pack versions of 54xx parts often had a different pinout from the DIP ones. Is that what you are talking about?
Online tooki
« Reply #18 on: Today at 07:22:14 pm »
All of those together don't even come close to being the full list of 74-series logic families. :P
Online coppice
« Reply #19 on: Today at 07:26:56 pm »
Its not all the 74 series, as someone else noted, but I think its all the bipolar ones. There were also related families of 74 compatible devices, like the Am25xx and Am29xx series of Schottky TTL chips, various things from Signetics (e.g. early forms of programmable logic), and others.
