Author Topic: How to connect negative resistance ?  (Read 2703 times)
Offline Michael GeorgeTopic starter
  • Country: eg
« on: October 02, 2015, 01:16:30 am »
I was reading this article about negative resistance:
https://www.maximintegrated.com/en/app-notes/index.mvp/id/1868
Would you tell me where the two terminals of negative resistance are, Please ?
Any resistor have two terminals. If I made a negative resistance as shown in the figure, Where are the two terminals?  I need to connect negative resistance in series (or in parallel) with other positive resistors but I don't know how, because I don't know were the terminals of the negative resistor are.
there are three possibilities in my mind:
1- Two terminals are Vin and Vo.
2- Vin and ground.
3- Vo and ground.
Thank you very much,
Offline Paul Rose
Re: How to connect negative resistance ?
« Reply #1 on: October 02, 2015, 02:07:06 am »
  • Country: eg
« Reply #2 on: October 02, 2015, 08:11:43 am »
@Paul Rose
Thank you for answering my question, I would be very grateful if you would tell me more about this circuit.
Upon your answer "Vin is one of the negative resistor terminals". I will connect Vin to a terminal of a positive resistor. so that they are in series. I expect that the circuit will work like a short circuit, Am I right? If no, How can I connect a positive resistor with the negative resistor?
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #3 on: October 02, 2015, 11:28:32 am »
It wouldn't act like a short, more like a comparator.
If you applied a positive voltage to the input (like in your example), the opamp's output would slam into the positive rail.
If you applied a negative voltage, it would slam into the negative rail.
You can't have it behave like a short, because that would mean that it should be able to pull an infinite current, which would only be possible if there was an infinite voltage across resistor R3.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
  • Country: eg
« Reply #4 on: October 02, 2015, 04:47:46 pm »
So, How can I connect a series positive resistor to a negative resistance op-amp?
Offline Dave
  • Country: si
« Reply #5 on: October 03, 2015, 04:03:49 am »
The same way you just did.
