I am working on a sdr receiver with 74HC74 and 74HC4053 as a QSD mixer. I built the circuit and 74hc74 does fine job by dividing input frequency by 4. However, at 74HC4053 outputs I get the same divide by 4 at input and output. I have traced all the connections everything looks fine. What could be the issue?
Please see the attached circuit.
So for example, at 10Mhz input frequency to 74HC74, Input at Pin 9 and 10 of 74HC4053 is 2.5 Mhz (divide by 4 from 74HC74). However, at pin 1, 2, 3 and 5 of 74HC4053 I get same 2.5Mhz as output too.
