Author Topic: Relay overcurrent protection without reset button  (Read 1803 times)
Offline soldar
Re: Relay overcurrent protection without reset button
« Reply #25 on: March 24, 2024, 11:15:03 pm »
The following users thanked this post: Zero999
Offline ElectricalTopic starter
  • Bananas Kiwi Cooked In A Meatball
« Reply #26 on: March 25, 2024, 05:09:11 am »
Yeah, it's something like this. An automatic reset circuit breaker.
But this youtube video shows something different.
It's a DC circuit for battery with high amperage that works like a spring when it becomes hot. A mechanical hardware that cuts the current for high amperage.
So not properly electrical logic with relay.
But beautiful answer.
Much appreciated!
TNX soldar
'by!
P.S. Since there is someone still interested in the post I'll show you this too:
https://www.st.com/en/power-management/e-fuses.html
It is an electronic fuse that self-resets.
But it's nicer when you do it yourself.
Re-'by
« Last Edit: March 25, 2024, 05:44:27 am by Electrical »
Pizza electronics with electric water fantabeer and sprite coke
