Author Topic: Product idea. 'Watchdog' mains power timer.  (Read 1631 times)
Offline philbx1Topic starter
« on: October 15, 2011, 06:36:41 am »
Hi all,
Just had a thought about a possible project.
This is basically just an adjustable timer circuit that cuts power if it hasn't been switched
off after a predetermined period.
This is NOT a countdown timer as such, just something that would start timing once power is applied
and shut off a relay if the timeout had elapsed.
I'm thinking uses like air conditioners, soldering irons, clothes irons, watering timers (even TV's etc.).
Offline Zero999
  • 0999
Re: Product idea. 'Watchdog' mains power timer.
« Reply #1 on: October 15, 2011, 03:11:46 pm »
You can buy timer relays to do that.
