Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
C-Bus optocoupler
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: C-Bus optocoupler (Read 1088 times)
hazmoment
Contributor
C-Bus optocoupler
on:
October 15, 2018, 09:32:43 am »
Hey up. Can anyone help with a wee problem Im having. with an optocoupler. Ive Just replaced an Optocoupler and a blown triac out of a C-Bus 8channel dimmer module and managed to get it working but only in the on or off state, I have no dimming. I believe the problem to be with the optocoupler i chose (vishay VO3062) to replace the original IL440-2. To prove that this is the cause of the problem i installed another VO3062 on another known good channel and gave me the same results, But I am not too experienced with optocouplers and what would be causing this behaviour. Can anyone point out the differences between the two which may be the cause of this? Or a more suiting replacement opto!?
https://pdf1.alldatasheet.com/datasheet-pdf/view/114398/VISHAY/IL440-2/+0144--VyhSHwadLPzCNpw+/datasheet.pdf
https://www.vishay.com/docs/83748/vo3062.pdf
Cheers! Hazmoment.
Logged
tsman
Frequent Contributor
Country:
Re: C-Bus optocoupler
Reply #1 on:
October 15, 2018, 01:46:14 pm »
Basic C-Bus dimmers are leading-edge dimmers so the additional zero-crossing circuit in your VO3062 will interfere with it and stop it from dimming correctly. You need an optocoupler without a ZCC.
Logged
hazmoment
Contributor
Reply #2 on:
October 15, 2018, 05:10:08 pm »
hey thanks! Why have zero crossing current built in to the opto? Any benefit in other applications? I will order a few of another type to try!
Logged
tsman
Country:
Reply #3 on:
October 15, 2018, 05:19:21 pm »
It causes less interference and lower inrush current since it'll be switching when the AC waveform is at 0V. They're useful if you just need on/off and not trying to do phase angle control.
Logged
hazmoment
Contributor
Reply #4 on:
October 15, 2018, 06:02:43 pm »
Gotcha. I have found this opto i hope will do the job seems to match the specs at least as far as i can tell.
https://nz.element14.com/vishay/il420/optocoupler-phototriac-5300vrms/dp/1469561
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
C-Bus optocoupler
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
