Hi Folks, I recently purchased a Rigol DSA815-TG primarily for EMI debugging/snooping. I've purchased and made a few near field probes and current clamps and been busy crimping coax connectors to RG174/LMR100 and generally getting the RF side of things put together.
So, next on the list was a LISN to check conducted noise issues from DC power inputs. Saw the Tekbox unit and since it is nominally open hardware with schematics/bom and layout available I figured it would be cheaper* (and more instructive) to build one up versus purchasing it ready made.
First step was to verify component availability from the tekbox bom (mostly digikey stuff) and then do my PCB layout since I prefer to have my own database versus someone elses gerbers. Created a few footprints and then layed the board out being reasonably faithful to the original layout. I used a gerber viewer to measure some of the key dimensions (especially the inductor spacing) to replicated it into my pcb cad file.
To get a netlist I entered (from scratch) the schematic into Orcad and here's a screen capture,
essentially the equivalent of the tekbox schematic (can be found at
www.tekbox.net):
![](http://www.taskled.com/dsa_lisn/lisn_dsn.gif)
Once I had the netlist I could import it into the pcb cad program and verify all the footprints and connectivity. A couple of hours later and here's a screen capture of the PCB layout I put together:
![](http://www.taskled.com/dsa_lisn/lisn_lay.gif)
The layout was sent off to PCB fab about a week ago, so I should receive boards back this coming week. Simple 2 layer board, soldermask/silkscreen etc. Ordered 20 boards since their individual cost is somewhat minimal compared to setup/shipping. More about that later. I ordered components from Digikey & Mouser and most of them are pretty cheap so 20 sets of parts are in my hands. The only parts I didn't order up in volume were the box, bnc connector, GDT etc. I order from Digikey often (too often), so getting more of those parts later is a non-issue.
With one box in my hands I decided to move ahead (since boards are in fab and dimensions are cast in stone) and start drilling some of the holes - for the PCB and BNC to start with.
So, here's the box with a few holes, small drill press makes life easy and a step drill does a neat job on the larger BNC hole. Next to the box is a 1:1 print of the layout, makes it easier to visualize and verify mounting location and hole placement.
![](http://www.taskled.com/dsa_lisn/lisn_box.jpg)
To verify the air wound inductors were the values claimed in the original schematic I wound a test inductor with some scrap wire onto the former and then checked it with my DE-5000 and sure enough inductance was in the 1uH range. I'm still waiting on the nominal new 1.4mm diameter (16awg) enameled wire to arrive - should turn up Monday. So, I turned a 17mm former on my minilathe in preparation for winding the actual inductors.
Here's a picture of the former machined from some scrap delrin with the inductor wound on it:
![](http://www.taskled.com/dsa_lisn/lisn_indw.jpg)
This was wound from scrap wire (16 awg as it turns out) that I recycled from a power inductor. I had to straighten the wire so it still looks a bit rough. The results should be nicer when I get the new wire that comes on a spool.
Based on the physical dimensions of the inductor, I entered the parameters into an online calculator:
http://wcalc.sourceforge.net/cgi-bin/air_coil.cgiThe coil former is 17mm diameter, so the effective coil diameter (at 1/2 the thickness of the wire) is (17mm + 0.7mm x 2) = 18.4mm. The coil measured length is approximately 12.4mm. Wire diameter is 1.4mm and 7.5 turns. Calculated frequency independent inductance is about 1.02uH
![](http://www.taskled.com/dsa_lisn/lisn_indc.gif)
and here is the DE-5000 reading of the inductor. Certainly close enough. I did calibrate the DE-5000 with the croc clip adapter plugged in.
![](http://www.taskled.com/dsa_lisn/lisn_indp.jpg)
Pic of some of the parts waiting for the PCB's to turn up:
![](http://www.taskled.com/dsa_lisn/lisn_parts.jpg)
That's where I'm up to at this point. Hopefully later in the week I'll have the PCB's in hand and can assemble up my unit. I'll post up more pics as the build proceeds.
*So, what about the other 19 boards?? I figure if some folk on this forum want to buy a kit I can purchase the remaining components and ship them out as kits. I'll include the PCB, all the components, banana jacks and the BNC that need to be soldered to the board and the wire that you'll need to wind on a former. I won't include the box. Cost to cover the PCB/components (likely $30 per 'kit') + mail/packing (which will depend on US/international).
Most of the discrete components are SMD, so you need to be comfortable soldering those parts - though on this board they are quite large (0805 is the smallest part)... Anyhow, first let me get the PCB's in and build one unit up.
cheers,
george.
