Author Topic: converting power up sequence into automatic using pulses reccomendations  (Read 280 times)
Offline john23Topic starter
  • Country: aq
Hello, In the photo and datasheet attached and i have a power up sequence of CGHV1A250F.
I need to make circuit which makes it autimatic using a delay between pulses.
What logic do you reccomend me to use so with pulses i could implement this startu sequence?
Thanks.
Offline xvr
  • Country: ie
    • LinkedIn
MCU (if already exists) or just shift register (like 74HC164)
Add: 74HC299 will be better - it could provide both turn on and turn off sequence
« Last Edit: May 25, 2024, 09:02:06 pm by xvr »
