Author Topic: kWeld - "Next level" DIY battery spot welder  (Read 342617 times)
Offline tatus1969Topic starter
  • Resistance is futile - We Are The Watt.
    • keenlab
Re: kWeld - "Next level" DIY battery spot welder
« Reply #775 on: February 21, 2024, 03:49:19 pm »
Sorry if this is not the right thread to post this.  I couldn't a find a kweld forum, or a general spot welding forum...
I have kweld (with super caps) and it's been great so far for batteries.
Now, I need to "stick" wires to some hardened steel rods. These are short rods, 3mm diameter, 8mm long.  I need to attach the wire to the end, at 90 degrees to the rod.  The wires are used detect when a mating part is in contact, so minimal current. (kinematic coupling)
So a few questions -
Will spot welding copper wire to steel work?  Is copper too low resistance, or should I try a different material?
Can I weld a thin wire to a larger rod?  Will the heat dissipate through the large rod without welding?
Should I be placing both probes next to each other when trying to make the weld, or can I place one probe on each end of the rod.  The standard probes are quite large to place both on the end of a 3mm rod.  I may need to make smaller ones.
I can't say much about that, other than that welding copper wires to steel rods is possible in general. A customer of mine had sent me this picture, quite a while ago:
https://www.keenlab.de/wp-content/uploads/2017/12/kWeld-example-strand.jpg
We Are The Watt - Resistance Is Futile!
Offline branadic
  • Sounds like noise
« Reply #776 on: February 22, 2024, 02:59:14 pm »
It should be possible, but you would need a tungston electrode at least for the copper wire.
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline p.larner
« Reply #777 on: February 25, 2024, 07:35:37 pm »
years ago at the welding institute to sit exams there was a big stainless steel cylinder about 1m dia and 1.5m tall it had a wall thickness of about 4 inches,in its top was a copper plug welded into it,it was electron beam welded,it was a part of a flask for vitrified nuke waste.
Offline branadic
  • Sounds like noise
« Reply #778 on: May 31, 2024, 11:38:01 am »
For quite some time I was looking for a proper enclosure for the welder and the caps board. I recently found Case for kWeld and kCap spotwelded with 120mm fan and thought it looks rather nice, compared to many other solutions. So I gave it a print and some hammer finish paint, which is currently curing. In case you are searching too, I can recommend that solution.
Edit: Image added.
-branadic-
« Last Edit: May 31, 2024, 09:02:48 pm by branadic »
The following users thanked this post: armandine2
Offline Jesserosco
« Reply #779 on: June 22, 2024, 05:43:37 am »
Any updates to the HSTNS-PD05? I just ordered the ksupply and kcap and have this power supply. The pin out looks exactly like the HSTNS-PR01.
