Author Topic: 5 Transistor ESR Meter Design  (Read 332952 times)
Offline m3vuv
Re: 5 Transistor ESR Meter Design
« Reply #350 on: October 20, 2021, 01:15:52 am »
is there any reason c3 is 22nf not 10 nf as in the original schematic?
Offline thejazzcat
  • Country: co
« Reply #351 on: July 08, 2022, 12:51:00 pm »
I'm building this ESR Meter but haven't been able to get the analog meter. I have a couple of questions.
Could I use the 60uA scale on my Kaise SK-120 Multitester as a substitute? Any risks on the unit that I should consider?
Can I replace the square wave oscillator for any of the available designs on the web? I have seen some IC555 that are quite simple and can have some controls to vary the frequency and the voltage output (would that be a handy thing to have with this tester?).
All the best.
Offline strawberry
  • Country: lv
« Reply #352 on: July 08, 2022, 04:09:33 pm »
All the best.
100uA
https://www.aliexpress.com/item/32360422161.html
Offline Texmisure
« Reply #353 on: December 04, 2022, 02:21:42 pm »
Hello Jay_Diddy_B,
Can you add a led indicator for a shorted capacitor? Thank you for your great job.
Online Jay_Diddy_BTopic starter
« Reply #354 on: December 18, 2022, 02:15:42 am »
Hi group,
To celebrate the 10th anniversary of the 5 transistor ESR Meter and my first post on the EEVBlog, I am working on a new version with an additional circuitry to detect a shorted capacitor.
Here is a little teaser:
I have added two transistors to detect the shorted capacitor.
I will share more information when I have built and tested design.
KICAD version 5 is being used for the design. I will release all the files when they are ready if somebody wants to convert the design to thru-hole.
Best regards,
Jay_Diddy_B
« Last Edit: December 18, 2022, 02:17:34 am by Jay_Diddy_B »
The following users thanked this post: kripton2035, Cliff Matthews, labjr, old-jo
Offline kripton2035
« Reply #355 on: December 18, 2022, 08:54:30 am »
where is the led ? ;)
« Reply #356 on: December 18, 2022, 11:22:07 am »
kripton2035 and the group,
TP1-TP2  9V Battery
TP3-TP4 LED to indicate the capacitor is shorted
TP5-TP6 Capacitor being tested
TP7-TP8 Meter and zero potentiometer, in series
Best Regards,
Jay_Diddy_B
Offline thejazzcat
  • Country: co
« Reply #357 on: December 18, 2022, 12:53:31 pm »
I just finished my meter. I have a final question, what diodes can I use for meter protection? I see them on some of the builds on this thread.
Thanks in advance.
CE
« Reply #358 on: December 18, 2022, 03:37:02 pm »
thejazzcat and the group,
Thanks in advance.
CE
There are two kinds of diodes:
In the red area use 1-3A silicon diodes, the type is not important, they protect the ESR meter from a charged capacitor. Do not use Schottky diodes.
In the blue area use small-signal 15mA Schottky diodes. I use 1N5711. These are the rectifier for the meter.
Best Regards,
Jay_Diddy_B
« Reply #359 on: December 18, 2022, 03:41:48 pm »
Hi group,
A quick update on the new design, 7 transistors including shorted capacitor indication.
I have sent the files to JLCPCB for fabrication and assembly. I have opted for slow shipping. I will add the parts that they do not have in the basic collection. It will be a few weeks before I see the boards.
Best regards,
Jay_Diddy_B
The following users thanked this post: Cliff Matthews, old-jo
Offline kkamel
  • Country: eg
« Reply #360 on: December 18, 2022, 04:08:38 pm »
I used BAT 85 small signal diodes and they are working exactly the same as 1N5711.
Offline zoltanh
« Reply #361 on: December 18, 2022, 06:31:46 pm »
Thank you. When do you plan to release the files?
« Reply #362 on: December 18, 2022, 11:00:52 pm »
Zoltanh and the group,
I plan to release the files after I have tested it. I am confident that the original 5 transistor circuit will work properly. The additional two transistors to detect the shorted capacitor has been tested in LTspice. It works in simulation.
This is the first time I have had boards assembled by JLCPCB. They are saying 1-2 days to build the PCB and another 1-2 days to solder 80% of the components. I will add the 20% of the parts that they do not have in their basic catalog. Then there is shipping, by DHL from China to Canada. I expect that I will get them between Christmas and the New Year.
Send me a PM if you can't wait  :D
Jay_Diddy_B
Offline kkamel
  • Country: eg
« Reply #363 on: December 19, 2022, 05:51:52 pm »
Hi Jay,
I have been using your tester for almost two years now and I am using 9V battery and 7805 regulator and I have noticed that if the battery drops below 7.5V the behavior of the circuit is not stable always requires calibration. Is it possible to reduce the threshold of the circuit by using 3.3V regulator instead of the 5V? Another question is it possible to use switching mode DC-DC converter to reduce the consumption or the noise of smps will impact the circuit accuracy?
Thanks
Offline iMo
  • Country: bt
« Reply #364 on: December 19, 2022, 06:12:52 pm »
Do use a "5V low dropout regulator" or "LDO".. The 78L05/7805 needs at least 2.5-3V over the 5V at its input to provide a stable output (plus minus, it depends on the manufacturer). Also the vintage 78xx series takes 5-7mA just for the regulator itself thus killing your 9V battery soon.
The low dropout regulators are usually happy with less than 0.6V and their quiescent current is at least 10x lower...
« Last Edit: December 19, 2022, 06:16:36 pm by imo »
Offline kkamel
  • Country: eg
« Reply #365 on: December 19, 2022, 07:13:02 pm »
I will search for an LDO alternative.
Thanks
Offline strawberry
  • Country: lv
« Reply #366 on: December 19, 2022, 07:40:52 pm »
I made this LDO with UV OV OC
Offline kkamel
  • Country: eg
« Reply #367 on: December 19, 2022, 08:03:07 pm »
This is too much for battery regulation I was searching for direct replacement LDO and low quiescent current.
Offline strawberry
  • Country: lv
« Reply #368 on: December 19, 2022, 08:29:33 pm »
standby ~2uA
operation ~1mA
TLV431 currents could get into uA range
« Reply #369 on: December 20, 2022, 12:49:10 am »
hi group,
the new version uses the AMS1117-5 regulator. It needs a minimum load, but the dropout voltage at the ESR meter current is less than 1V and the price is very low.
Jay_Diddy_B
« Last Edit: December 20, 2022, 01:01:05 am by Jay_Diddy_B »
Offline bostonman
« Reply #370 on: December 20, 2022, 02:25:37 am »
Is using a wall wart a better alternative or is it too noisy?
« Reply #371 on: December 20, 2022, 04:01:24 am »
A wall wart will work fine. You could use a regulated wall wart and short out the regulator.
If you use a wall wart, check out DiodeGoneWild on YouTube. A lot of wall warts are dangerous with only enamel insulation between the output and the mains.
Link:
I use my ESR meter for a few minutes each year. With this low level of use a 9V battery works fine.
Jay_Diddy_B
Offline Texmisure
« Reply #372 on: December 20, 2022, 12:19:54 pm »
Hi group,
Jay_Diddy_B
Thank you, we are ok for the next 10 years😉
Offline alexandre MC
  • Country: br
    • xxxxxxx
« Reply #373 on: December 20, 2022, 12:39:15 pm »
Olá..
Poderia me dizer qual a tensão entre TP3 e TP4.  Montei o esquema e as tensões ficaram iguais as da foto, porem meu amperímetro ( 50 microampères ) não oscila.
Offline kripton2035
« Reply #374 on: December 20, 2022, 03:23:16 pm »
another possible improvement : add the same high voltage protection than on the esr to voltmeter adapter...
