Hi group,
I have completed the assembly of the thru-hole version. Here is a picture of the assembled board:
![](https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/?action=dlattach;attach=269809;image)
If you are trying to read the colour codes, most of the resistors used are 1 or 2% so they have an extra band.
I also substituted a 3.3 Ohm resistor for R10, because I didn't have any 3.0 Ohms.
Here is a photograph of the board being tested:
![](https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/?action=dlattach;attach=269811;image)
I have the board hooked to a General Radio Decade box, out of camera, set to 1 Ohm.
I needed a 12k Ohm resistor in R24 position.
Regards,
Jay_Diddy_B (Recovering ESR_Nut)
