Author Topic: 400Hz, three-phase power supply for aviation stuff  (Read 9817 times)
Offline Artlav
  • Country: mon
    • Orbital Designs
Re: 400Hz, three-phase power supply for aviation stuff
« Reply #25 on: April 14, 2017, 07:11:34 pm »
What about a mechanical solution?
Get a BLDC motor, i.e. from an RC plane, spin it with another motor (fixed speed to get the right frequency), wind a transformer to get the right voltage (if not close enough).
Much simpler than trying to build an inverter.
Technical term is Umformer, i think.
Offline tecman
« Reply #26 on: April 14, 2017, 09:29:36 pm »
I believe only in Germany
Offline james_s
« Reply #27 on: April 14, 2017, 10:43:14 pm »
The term I've heard for those is "rotary converter" many of them have a single armature with a commutator on one end and slip rings on the other. They were made for converting DC to AC as well as converting AC of one frequency to AC of another, or single to polyphase.
