Author Topic: DG509 beyond Vdd  (Read 3589 times)
Offline RESTopic starter
DG509 beyond Vdd
« on: September 08, 2016, 12:25:46 pm »
Goodday,
Not sure if a DG509 can withstand higher voltages on the input pins while operating at 5V single supply. Want to monitor cell voltages and don't want to waste an opamp on each cell. Datasheet DG509 tells:
• V+ to V- analog signal swing range
• 44 V power supply maximum rating
But:
• Digital Inputs a, VS, VD (V-) - 2 to (V+) + 2 or 20 mA, whichever occurs first
Inputs float over each cell. Do inputs DG509 still need protection? (clamp diodes for example?)
Thanks.
Offline Zero999
  • 0999
Re: DG509 beyond Vdd
« Reply #1 on: September 08, 2016, 09:15:05 pm »
The DG509 has diodes connecting all of its inputs/outputs to +V & -V to protect them from over voltage. It will be fine, as long as the current is limited to a safe level, to protect the diodes. Like any analogue switch it cannot switch signals outside its power supply rails.
Offline EmmanuelFaure
« Reply #2 on: September 08, 2016, 09:26:28 pm »
Actually not "any"!
Offline Zero999
  • 0999
« Reply #3 on: September 08, 2016, 09:34:10 pm »
Actually not "any"!
No, not unless the analogue switch has a built-in charge pump to boost its internal supply voltage.
Look at the schematic of a typical analogue switch:
https://wiki.analog.com/university/courses/electronics/electronics-lab-28
« Reply #4 on: September 11, 2016, 01:07:41 pm »
Thanks you. That's not a "typical" analog switch, but a CMOS analog switch.
Using non complementary topology, you can switch voltage well beyond supply voltage. CMOS analog switches are very common (Cheap to manufacture, classic process), but that doesn't mean they're the only solution available.
Offline Zero999
  • 0999
« Reply #5 on: September 11, 2016, 02:03:57 pm »
Please provide some example part numbers?
Offline Kleinstein
« Reply #6 on: September 11, 2016, 05:18:05 pm »
To go really beyond supply one could use optocouplers with FET output,e.g. H11F1 or optomos types.
Offline Zero999
  • 0999
« Reply #7 on: September 11, 2016, 08:01:51 pm »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #8 on: September 12, 2016, 01:17:13 am »
What other kinds are there?
Seven Transistor Labs, LLC
Offline Zero999
  • 0999
« Reply #9 on: September 12, 2016, 08:33:19 pm »
I wondered that too.
Offline T3sl4co1l
« Reply #10 on: September 13, 2016, 04:47:17 am »
Not to be pejorative -- there are other kinds (if not nearly as common, today!).  I'm honestly wondering what you're familiar with.
