Author Topic: Programming your own quartz oscillators (EPSON SG-800x or others?)  (Read 1888 times)
Online ebastlerTopic starter
Epson has several nice series of programmable oscillators based on a quartz+PLL. Even the basic versions, SG-8002 and SG-8003, offer a lot of flexibility in the clock rates that can be set, and decent stability. (50 to 100 ppm over a 90°C temperature range; the more advanced series go down to 10 ppm.) You program the desired freuqncy once, and then just use them like a fixed-frequency 4-pin oscillator package. I am currently looking at an application which requires an odd clock rate, and these look like a great alternative to a custom quartz.
Digikey offers them with custom programming to the clock rate you want. Their price is reasonable at 3.56€ in single quantities. But I would prefer the flexibility of ordering blanks and programming them at home. Epson also offers a special programmer; quite reasonably priced at around €250, but still difficult to justify for a (single?) hobby project.
Is anybody aware of a generic programmer which can handle these oscillators, or a homebrew solution to program them? I did search the web a bit but have come up empty. Thanks for any hints you might have!
If you are aware of alternative products which can be programmed easily (say via I²C), that would be helpful as well. But I would be looking for something that can retain the programmed frequency, so it can start up on its own upon power-on. And it would need to be stable to ~100 ppm, which seems to rule out any MEMS-based oscillators. Thanks!
Re: Programming your own quartz oscillators (EPSON SG-800x or others?)
« Reply #1 on: January 07, 2019, 05:22:26 am »
I realize that this is a bit of a niche topic, but I'll give it a bump anyway:
Has anybody come across a cheap solution to program the Epson/Seiko SG-800x series oscillators?
Or do you have other recommendations for a programmable oscillator with decent stability (100 ppm) which can store the programmed clock frequency (non-volatile)?
The following users thanked this post: matseng
Offline amyk
« Reply #2 on: January 07, 2019, 12:22:28 pm »
Related: https://www.eevblog.com/forum/projects/wip-reverse-engineering-the-programming-protocol-for-sitime-sit8008/
Do Epson have any patents on these? Perhaps that may give a clue on how to program them.
The following users thanked this post: ebastler
