Hello,
I have an Oxygen sensor that outputs a 4 -20 mA signal. I also have an IFM DP2200 to receive the signal on the PLC side.
I am having trouble to understand how to wire them together.
The DP2200 is supposed to supply power (24 vdc) to the sensor. However, the sensor already receives its power from a different power supply (12vdc).
See below diagrams.
Regards,
