Hi all,
My idea is to connect the USB2.0 lines to an USB2.0 hub IC and connect the USB3.0 data lines to an USB3.0 device. This way i will have 3 more USB2.0 ports. I have looked at some USB3.0 hub ic's (USB5533B and TUSB8040 to be precise) and it looks like there is two separate hubs for USB2.0 and USB3.0 inside the IC. I don't need more than one USB3.0 so i have come up with this.
Can i use USB2.0 and USB3.0 separetly? Will this couse enumarating issues for the USB3.0 device? Can i get away with this or do you recommend i should just use an USB3.0 hub IC? I have attached a block diagram;
