Author Topic: 3 phase motor drive for low voltage high current (not a hobby esc)  (Read 3484 times)
Offline qwaarjetTopic starter
  • Use your imagination and pretend its linear.
I'm looking for a 3 phase drive that can operate in open loop or use feedback like back EMF or encoder or both preferably. This need to drive bldc motor from a quadcopter for a bench experiment for a school lab so low voltage but fairly high current. I don't want just a regular ESC because I cant control the feedback parameters but most VFDs require a encoder and cant be run open loop. Building a custom solution is an option but I would rather not it there is commercial product that could be used. Anybody got an idea?
« Last Edit: March 05, 2015, 04:34:52 pm by qwaarjet »
Offline Seekonk
Re: 3 phase motor drive for low voltage high current
« Reply #1 on: March 05, 2015, 02:58:17 pm »
Hobbyking has plenty cheap.
« Reply #2 on: March 05, 2015, 03:20:46 pm »
I can't control the feedback on a regular hobby drive almost all of them use back emf  for feedback. I want one that can run true open loop
Offline eneuro
Re: 3 phase motor drive for low voltage high current (not a hobby esc)
« Reply #3 on: March 05, 2015, 05:37:46 pm »
This interesting sensorless BLDC driving TI technology InstaSPIN™-BLDC, however not sure if HobbyKing has already something which implements this.
There is quite nice introduction - maybe something more than kits are commercially available?  :-\
Definitelly will put my hands on this technology after a few other projects are finished, while need drive a few BLDCs in another projects and it could be nice use cheaper BLDC motors without Hall sensors ;)
12oV4dWZCAia7vXBzQzBF9wAt1U3JWZkpk
“Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine”  - Nikola Tesla
Offline mazurov
« Reply #4 on: March 05, 2015, 10:09:28 pm »
If you attempt to run BLDC open loop you'll get a stepper with very large step. Any hobby ESC runs open loop at startup with characteristic jerking motion of the rotor. You can rotate a BLDC like that with 3 switches by energizing 2 windings at a time in a certain sequence. I made a controller once using Allegro A4960 ( http://www.circuitsathome.com/diy-2/advanced-brushless-dc-motor-controller ); if you screw up the settings of the chip you will get open loop.
With sufficient thrust, pigs fly just fine - RFC1925
