Hi there, It's been I while that I wanna build a battery pack for my skate board. It is originally based on PbA battery. However, another thing that keeps bothering me is battery recycling. Besides, I have access of a bunch of cells from notebook batteries. So, I wanna reuse it. Please, understand that this is my goal!
Thus, I will use electronics to improve it and keep it safe...
I actually know the problems and safety issues regarding parallel and series arrangement. BMS can solve most of the problems for series applications, however, parallel doesn't. To be more clear, I wanna mix batteries with different capacities. Ex: 2500mAh (4.2V) and 1500mAh (4.2V), in order to reach 4000mAh.
1. My first approach is reduce current drain, for instance 3Amax (2500 + 1500). It seems reasonable for stationary applications, but not for transiente like the skate board.
2. I also wanna add a second layer protection to work with BMS, and here is my question.
I will produce a pcb board as
Patrick did:
However, I wanna place a SMD termistor near each cell connection. If temperature increase, a SMD mosfet, driven by a pull-up resistor will conduct and change the logic level to zero (which is the voltage that BMS is monitoring).
I need some tips and opinions. I also hope that, if BMS stops reading 3.7V, but go to 0V, it will open the circuit.
