Author Topic: pcb resistors  (Read 3150 times)
Offline trevwhiteTopic starter
pcb resistors
« on: July 13, 2012, 08:49:17 am »
Hi, as any one used a pcb track as a current sense resistor? I found a current sensor ic that recommended a track pattern that gave 150mOhm resistance with 5% tolerance. I believe the tolerance was for manufacturing rather than temperature changes.
I was wondering if such 'pcb resistors' remain within tolerance w.r.t. temperature?
Thanks
Trev
Offline PChi
Re: pcb resistors
« Reply #1 on: July 13, 2012, 09:49:06 am »
I have worked on product that used tinned copper wire not the PC track. It's a cheap idea. The temperature coefficient of change of resistance with temperature for copper is high. The data that I have is alpha = 0.00428 which I think means that it changes by 0.4% / degree. Also over load trashes the track hence the PCB.
Online Psi
Re: pcb resistors
« Reply #2 on: July 13, 2012, 09:56:32 am »
You can also get hall effect current IC's where you have a PCB trace running under the chip and the sensor inside picks up the current through the IC package. I don't think the track width matters much with those.
It's not very accurate though.
Re: pcb resistors
« Reply #3 on: July 13, 2012, 09:58:30 am »
Hi
Thanks for the reply. It doesn't sound the best idea really. Maybe for detecting some current it would be okay.
Trev
Online Psi
Re: pcb resistors
« Reply #4 on: July 13, 2012, 10:11:20 am »
Yeah, it's no good if you need accuracy.
Offline ejeffrey
Re: pcb resistors
« Reply #5 on: July 13, 2012, 02:14:33 pm »
Track resistors can be useful for things like current sharing resistors but they aren't very good for measurement shunts unless you really don't care about accuracy.
Online Zero999
  • 0999
Re: pcb resistors
« Reply #6 on: July 15, 2012, 12:45:53 am »
I agree, it's no good for accuracy but the question is why are you measuring the current in the first place?
Is it for overload protection? If so, a PCB trace may be ideal, as copper has a positive temperature coefficient so the reading will increase with the temperature, which might be good if the sense trace is near the device being protected.
