Author Topic: Small Oven, for 2x LT1236, (Python Reference) No1  (Read 33061 times)
Offline daqq
  • Country: sk
    • My site
Re: Small Oven, for 2x LT1236, (Python Reference) No1
« Reply #25 on: January 06, 2016, 03:44:08 pm »
Very nice! Impressive that you got such a small reaction to outside temperature.
Perhaps it is even possible to create 2 planes on either side and connect them through some via's and use that is a heater?
Using PCBs as heaters is done (seen it in 3D printers), but the problem is that they have very low resistances - as such you need a low voltage with a lot of current.
Stupid question: Why not add the styrofoam insulation inside the metal enclosure? If one wants to have more "thermal mass", just place a smaller metal enclosure inside the insulated enclosure?
I'd say it would be better to put the metal enclosure into an insolation - that way you get a good thermal connection to the heated device and a lousy thermal connection to the outside.
Offline Alex Nikitin
  • Femtoampnut and Tapehead.
    • A.N.T. Audio
« Reply #26 on: January 06, 2016, 03:46:50 pm »
together with a A=2 LTC2057 amplifier with LT5400 as gain setting resistor. Sure, longterm stability would be worse the frist 2000h, but after it has aged, well...???
You can get a pretty decent x2 precision amplifier using one INA133 inside the enclosure.
Cheers
Alex
Offline Kalvin
  • Embedded SW/HW.
« Reply #27 on: January 06, 2016, 03:58:09 pm »
Total brainfart from my side |O I thought placing the heating transistors with a heat sink inside the insulated metallic enclosure would give some benefit. Like you said, insulating the heated enclosure is the Solution.
« Last Edit: January 06, 2016, 04:00:07 pm by Kalvin »
Offline branadic
  • Sounds like noise
« Reply #28 on: August 24, 2018, 11:10:30 am »
Any news or results on that experiment?
-branadic-
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline branadic
  • Sounds like noise
« Reply #29 on: August 18, 2021, 08:03:12 pm »
I finally managed to power up LT1236LS8 assembled on a PI flex pcb, attached with a thermal adhesive pad to a QH40A crystal heater. The assembly is insulated and inside a glass flask. I still have a bunch of those flex boards left, so if someone is interested in let me know. Can ship them via a letter if you pay for the shipment.
-branadic-
