Author Topic: Fixing untented vias under BGA's  (Read 2217 times)
Offline elmohandisTopic starter
« on: May 05, 2015, 08:02:45 pm »
Hi Guys,
I recently spun a board with 3 BGA's (1.0mm pitch 676-pin FPGA + 2x DDR3 SDRAM 0.8mm pitch).
The board just came in and I noticed that I forgot to tent the vias under the BGA's (oops!).
I am considering the following fix before sending it off for assembly:
1. Order a stencil with cutouts in place of the vias to be tented.
2. Apply curable solder mask to the vias only using the stencil.
3. Cure with UV.
Can someone share some advice? Is there a better way?
Thanks!
Offline marshallh
    • retroactive
Re: Fixing untented vias under BGA's
« Reply #2 on: May 06, 2015, 04:09:51 am »
Try that method if you want, better is probably just to assemble it anyway. Just be more careful with the paste.
Verilog tips
BGA soldering intro
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #3 on: May 06, 2015, 04:17:09 am »
I recently did some BGA site repair and came across this product: http://www.soldertools.net/bga-stencils-stencilquik/
Essentially, the stencil has adhesive on the bottom such that it acts as solder mask as well as stencil for solder paste application. It is left in place when reflowing the BGA, which also prevents solder ball collapse and shorts.
I also purchased a PCB rework kit, which contained high-temperature epoxy that can be used for touching up solder mask in case of damage. However, it was very hard to do properly since my pitch was 0.8 mm. The Stencilquik approach would likely be easier for you.
http://www.circuitmedic.com/products/201-2100.shtml
/John.
« Last Edit: May 06, 2015, 04:19:12 am by John_ITIC »
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
