Author Topic: 24VDC Serial Logic Level Shifter: Give me your thoughts!  (Read 666 times)
Offline Str1kerTopic starter
« on: July 23, 2024, 07:49:02 pm »
Hey everyone,
I recently acquired an old Flip-Dot destination sign from a bus. After doing some research, I found out that it uses the IBIS standard, which is a hardware-modified serial interface, to communicate with the main controller that is operated by the bus driver. The only difference from a normal serial interface is that it uses a 24V logic level for the communication.
I came across some old (hobbyist) level shifter schematics designed for this specific IBIS purpose. However, I thought I could come up with a better solution myself (where's the fun in using someone else's work, right?).
My goal was to design a solution that works with 3.3V and 5V logic levels, providing a universal solution for different control strategies building on this work.
I've attached my solution to this problem (T2 in the schematic needs to be replaced by a 2N2222). I'm eager to hear what you think of it and if you have any thoughts on how to improve this circuit.
(Side note: R5 and R6 have such a low resistance because the TX signal must provide at least 100mA on the output side)
By the way, I simulated my approach in Falstad's circuit simulator and tested it on a breadboard, and everything seemed to work properly.
Looking forward to your suggestions!
« Last Edit: July 23, 2024, 08:00:05 pm by Str1ker »
Offline BennoG
Re: 24VDC Serial Logic Level Shifter: Give me your thoughts!
« Reply #1 on: July 23, 2024, 08:01:22 pm »
I did a design that uses the AEIC-7272-S16 shifter to get to a decent 24V push pull output.
For receiving you can do a simple resistor divider (with some protection)
Benno
The following users thanked this post: Str1ker
Offline Phil1977
« Reply #2 on: July 23, 2024, 08:03:40 pm »
There are many ways to solve this problem, and if you are satisfied with your design - then go for it!
Just the points that could be improved:
- The "double-pull-down" design pulls a lot of idle power, especially with 24V. Why not use a push/pull driver?
- The receiving path can be realized just with a voltage divider + a zener. Is there any reason to use transistors?
- It´s recommended to user buffer/decoupling caps on level converters for all voltage levels.
« Reply #3 on: July 23, 2024, 08:13:36 pm »
Benno
Thanks for the suggestion! I wasn't aware that such an IC exists. I might keep an eye out for one that reliably operates on 3.3V. :)
« Last Edit: July 23, 2024, 08:15:23 pm by Str1ker »
« Reply #4 on: July 23, 2024, 08:26:41 pm »
I really appreciate your help!
- The "double-pull-down" is usually off, as the serial interface is in a high state when idle. The signal must supply at least 100mA (at least that's whats specified in the standard)... I guess it has something to do with multiple and "oldish" receivers.
- Simplifying the receiving part might work with the divider and a zener but I was not sure if a 5V receiver works with a maximum 3.3V high level that the zener creates (It shall work with 3.3 and 5V logic levels). I will give this idea a try in the upcoming days! :)
- Caps are also a good hint!
Offline BrianHG
« Reply #5 on: July 23, 2024, 08:41:33 pm »
Have you considered a mosfet gate driver IC?
3.3v logic inputs.
Enable inputs.
Available with multiple drivers per IC.
Outputs push-pull at 2+ amps peak, 100ma continuous wont be a problem.
Example devices which can support 25v:
https://www.infineon.com/cms/en/product/power/gate-driver-ics/irs4427s/
« Last Edit: July 23, 2024, 08:43:25 pm by BrianHG »
Offline BrianHG
« Reply #6 on: July 23, 2024, 08:50:51 pm »
Another dual gate driver, the IXYS IX4424NG claims 30v support, again multiple amps push-pull drive output.
Offline Benta
« Reply #7 on: July 23, 2024, 09:09:22 pm »
Just us a SPDT analog switch for the 3.3/5 -> 24 V translation.
The 24 -> 3.3/5 V translation can be done with a simple voltage divider.
« Reply #8 on: July 31, 2024, 01:10:56 pm »
Thank you all for your replies!! Your recommendations will help me in future projects.  :)
