Hello folks, I hope you are well!
I'm kinda confused by the statement of AD8099 datasheet. I'm planning to use ±5V supply, does the current values stated refers to current for each rail or combined?
Also, should I design the -5V rail against the "short circuit current" or "quiescent current"? AD8099 is the only one drawing -5V and the output is fed into two TLV3601 comparators.
Thanks for your time! I've included a clip of referenced datasheet in attachment.
Sincerely,
Muri
