Author Topic: 220V HSPY 400-01 Adjustable Power 400V/1A programmable Digital DC Power Supply  (Read 494 times)
Offline TronicTopic starter
Hi folks
I am trying to source a hybrid battery grid charger for a 2009 Toyota Estima Hybrid car and there doesn't appear to be any available so I have been looking at the DC power supply (220V HSPY 400-01 Adjustable Power 400V/1A programmable Digital DC Power Supply). Does anyone has any experience in using such a power supply to recondition a hybrid car battery?
Thanks.
Offline TheMG
Probably better if you can gain access to individual battery cells to use smaller lower voltage power supplies/chargers for this, or at least split up the pack into more manageable parts (safer too). The more cells you have in series the more chances there will be imbalances, which will be a detriment to attempts to "refresh" the NiMH pack. It could even be damaging if you plan on deep discharging it as part of the refresh process as weaker cells could go negative and that is not good for them.
