@joeqsmith, what I wanted to know is how much of that central strip did you cut away before and after the pad at the junction of the resistors?
thanks
enut11
Again, I'm using a razor blade so it's not exact. Basically, I used the length of the axial body. In hindsight, using a smaller gap may have helped improve the performance by adding a little more capacitance. Then again, maybe a little foil and some tape.... You may notice the gap is similar on the 0603 parts. It's certainly not optimum but as you can see, it can yield some decent results at lower frequencies.
I have ordered a few of the low cost attenuators. These may be a good starting point for your experiments.
@joeqsmith
I played around with the APPcad numbers for my 1.5mm double sided circuit board until I got 50 ohms.
What I do not know is the 'FR' value (dielectric) for my PCB so I assumed a mid-range figure of 4.6
Ended up with a 2.8mm central strip with 2.5mm gaps either side. Looks OK?
enut11
At lower frequencies, the software should do fine but I doubt you would want to pay to have a PCB made from better materials and controlled impedances. I would check with your board house before you settle on a design. Maybe even try a couple of different dimensions to hedge your chances.
Yikes! What a minefield cables can be. May be better off sticking to the lower HF area for the time being...
I've had a lot of fun playing with RF without having to resort to anything too crazy. There's no reason you can't use the Nano to experiment in the GHz range. I would like to see the Nano V2 3GHz unit. If you can believe the internet, they are now working towards 6GHz. That will be impressive.
