Curious what it looks like on the bottom. Should think the ground plane is continuous, in which case, yes, it would be quite a bit of capacitance (effective).
The transition itself is probably inductive, so it serves to level things out. But it might be they haven't done a good analysis of it either. Which could be empirical, or badly simulated, or painstakingly simulated..
