Author Topic: Can someone identify this connector?  (Read 1095 times)
Offline AndersJTopic starter
« on: October 06, 2021, 01:11:31 pm »
What connector family and type is this?
"It should work"
R.N.Naidoo
Offline TheMG
Re: Can someone identify this connector?
« Reply #1 on: October 06, 2021, 01:32:47 pm »
I often hear then referred to as "Cannon" connectors. Often used in military and aerospace applications.
They exist in an almost infinite number of different configurations for the pinout and keying, and come with either solder or crimp pins and in either threaded or bayonet style coupling.
There will be a part number stamped somewhere on it.
The following users thanked this post: AndersJ
Offline Neomys Sapiens
« Reply #2 on: October 07, 2021, 03:57:46 am »
Nearly sure due to the uncommon configuration of the bayonet lock:
VG95234 cylindrical reverse bayonet coupling, probably pinout 16S-1 (7 #16 contacts).
Made by Souriau, Glenair, ITT Cannon, Amphenol Air-LB..
Based on a German adaption of the threaded Mil-C-5015 connectors, therefore the 'VG' designation.
AFAIK there is a British adaption of it. There is some lettering just visible on the locknut. If you post that, I could verify this info.
The following users thanked this post: Excavatoree, splin, AndersJ
« Reply #3 on: October 07, 2021, 11:13:27 am »
Thanks for the very extensive reply.
I’ll get back to you about the hopefully visible lettering
as soon as I have access to the cable again.
« Last Edit: October 07, 2021, 06:48:00 pm by AndersJ »
"It should work"
R.N.Naidoo
« Reply #4 on: October 07, 2021, 08:18:05 pm »
Also helpful would be to take some mechanical measurements, especially of the connector front side.
« Reply #5 on: October 08, 2021, 07:32:45 am »
Text stamped on connector rotating part:
“7923 CANNON-G CA3106E16S-1P-B-F80
This answers the original question, didn’t see it first time…
Connector is 7-pole
Attaching pictures with rough dimensions and mating chassis connector.
« Last Edit: October 08, 2021, 07:34:48 am by AndersJ »
"It should work"
R.N.Naidoo
Offline EPAIII
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline dave_k
