No problem, just encapsulate them in an electronics grade silicone, and then place inside a PVC conduit that will be buried in the concrete. As they are 1 wire devices just use a CAT5 cable and place each sensor in the one pair, so that you have a long string of them after encapsulation to put in the pipe. Seal the far end and bring the tail end up through an elbow to a junction box in the wall, so that you can connect to it. When doing the concrete lay them down and tie to the reinforcing, and place the junction box in position, with 3m of cable free wrapped up in a bundle and cable tied to the junction box, the box being wrapped in heavy plastic for protection and to keep the builders from breaking it. After cure mark the conduit position and use the construction measurements to mark the sensor positions on the concrete with either some acrylic paint or stain.
