Author Topic: 18650 soldering iron  (Read 2317 times)
Offline daniel444Topic starter
« on: November 20, 2019, 12:47:41 pm »
soldering iron build
uses ngk glow plug , silicon nitride ceramic tip , 3mm tip , top of the line glow plug
25A momentary microswitch , beer keg stainless tube surround
fits a weller tip after being drilled out with 1/8 drill bit , then uses a small offcut of pyrolitic graphite thermal pad to hold it on by friction
switch needs to be held on about 1/3 of the  time for lead solder
pictured is a spare glow plug and a Chinese nitride glow plug i bought , the Chinese version wont fit the weller tips at 4.4mm but is cheaper and more readily available
draws about 10 amps , im NOT using the high drain 18650s if i were it might be to powerful maybe
Offline fmkit
  • Country: il
Re: 18650 soldering iron
« Reply #1 on: November 20, 2019, 01:28:10 pm »
  mine also looks crude,  unlike original temp.is contrlled w/MT3608 DC step_up,as well 18650 is under-voltage protected.
Offline ElectricPower
  • Country: no
  • I have many opinions but have no idea
    • Turer, fjas & slabberas
« Reply #2 on: November 20, 2019, 01:45:28 pm »
I found out yesterday that i'm not a REAL man when i saw the soldering iron this guy used. Take å look from (08:34) in this video  :-DD
Offline Black Phoenix
  • Country: hk
« Reply #3 on: November 20, 2019, 02:42:39 pm »
 :-DD :-DD :-DD :-DD :-DD :-DD :-DD
Ohhh damm, my sides!!!
« Reply #4 on: November 20, 2019, 02:59:40 pm »
That's insane, why have I never thought of using diesel glow plugs before, they'd be brilliant for all sorts of things
yes i might use it to vaporize some essential oils , with the solder tip removed of course , id like to do a torture test on the silicon nitride strength and inertness
« Last Edit: November 20, 2019, 03:03:06 pm by daniel444 »
Offline mikerj
« Reply #5 on: November 20, 2019, 05:28:31 pm »
Just need to add a PWM controller.  I'm wondering if it would be possible to derive the temperature by taking current & voltage measurement during the on period to calculate heater resistance..
Offline mikerj
« Reply #6 on: November 21, 2019, 12:36:53 pm »
I think the vape guys do that kind of measurement on the more sophisticated controllers.
A possible snag with many modern glowplugs is they integrate some kind of regulating element (presumably some kind of PTC)  in series with the heater element.  This may not be a problem since a soldering iron would be operating well below the normal regulated temperature.
Offline KL27x
« Reply #7 on: November 23, 2019, 02:01:14 am »
https://youtu.be/en8bh60K7m8?t=110
This is probably 12 years old. I just checked it. It still works. Microcontroller, PWM standy and autoshutoff. Single button interface.
