Author Topic: 170 Vdc, 3A/1A/250mA cc supply  (Read 2751 times)
Offline dcoig1Topic starter
« on: April 02, 2011, 12:00:07 pm »
I'm trying to build a charger like this: http://99mpg.com/Data/resources/downloads/gridchargerstuff/dual_stage_grid_charger1.pdf
but... i would prefer to build the supply as a single unit and not use so many separate 48v supplies, add a higher 3a initial charge, and adjust the trickle current to 250mA instead of 350mA.
The charger is for a honda insight nimh 144v battery pack which charges fully to ~170v.  There are 120 1.2v nom 6.5ah 'd' cells in series.
I am an electrician not an engineer so putting the charger together as prescribed is tempting, but something in me says there is a better way.
The goal is to top off the pack occasionally since the factory bms never charges the pack beyond 80%.  I can use either 110 or 220v.  I would like to keep as efficient as possible, but it is not a daily charger.
I need some help rectifying the situation, please help, all is appreciated!
