You need to read the data sheets.
With respect to tolerance on the +/- 15 V supplies for op amps, the relevant spec is the DC PSRR and CMRR, which allow you to calculate the shift in DC input offset voltage for a change in the DC voltages.
PSRR is relevant to the magnitude of the total voltage between the supplies, and CMRR is relevant to the mismatch in absolute values.
High precision in DC values is only relevant to normal op amp applications if a precise DC output is required when the DC signal input is derived directly from the supplies.
More important for normal applications is the hum, noise, and ripple (AC components) of the supply voltages, since PSRR and CMRR fall with increasing frequency.
Still, this is a quantitative question.
