Alright, I haven't done something like this since college, and I kind'a have the idea of what I need to do, but I can't seem to figure out.
I'm trying to generate a pulse from an input signal. The signal is normally high, and will go low to activate a device. The generated pulse should be HIGH for as long as the input signal is low, and after the input signal goes back to high, the pulse will remain ON for X seconds.
I started refreshing my memory about monostable multivibrators so I fired up Proteus to try and simulate something but it's just not working like the datasheet says it works, and I don't know if this is a simulator problem, or a circuit problem. Doesn't matter what values I set for R and C, the output pulse is always the length of the time constant.
