Author Topic: Design of an ESR Meter from Practical Television 1999  (Read 9444 times)
Offline Wil_Bloodworth
Re: Design of an ESR Meter from Practical Television 1999
« Reply #25 on: November 28, 2023, 08:36:42 pm »
Here is some test cap pics, the daggum thing looks to be right on the money. The meter pictured ranges from 0-300uA so at the 10 mark is 100uA or zero ohms. Tested 3 caps, one at under 1, one at 3 and one over 40 esr respectively. Meter scale and board pic also attached. Also the oscillator set at 5v peak to peak at pin 1 of U1. Frequency is off a tad but close enough. The bulb used was a JKL COMPONENTS / 6838 in the oscillator.
Very nice!
Online RoGeorge
« Reply #26 on: November 28, 2023, 09:23:20 pm »
Nice!  :-+
Do you happen to have any battery at hand?  It should be possible to tell which ones are discharged by measuring their internal resistance, or to tell which rechargeable from the same lot got more damage with time.
Offline Tim88Topic starter
« Reply #27 on: November 29, 2023, 12:47:14 am »
I want to get that protection circuit installed before I go checking any batteries. :)
Offline skipp
« Reply #28 on: December 01, 2023, 08:09:57 am »
Buy a kit and build one that's what I did. I am only just a beginner myself. but look on aliexpress they have them fairly cheaply.
Offline Hamelec
« Reply #29 on: December 01, 2023, 05:17:42 pm »
I don't know any kit which is able to measure the ESR incircuit and under supply voltage, like this one
« Last Edit: December 01, 2023, 08:08:19 pm by Hamelec »
« Reply #30 on: January 09, 2024, 08:34:03 pm »
Finally got the ESR tester done, found a very cool enclosure for it for $10, link below. I also attached a couple meter scale pics one colour and the other not.
https://www.aliexpress.us/item/2255800409490545.html?spm=a2g0o.order_list.order_list_main.11.12de1802Jjm7fX&gatewayAdapt=glo2usa
1976343-0
1976379-1
* meter bw.pdf (783.16 kB - downloaded 40 times.)
* meter colour.pdf (797.6 kB - downloaded 37 times.)
« Last Edit: January 09, 2024, 08:36:59 pm by Tim88 »
Offline soldar
« Reply #31 on: January 09, 2024, 09:44:50 pm »
Variations of this design have been going around for quite some time. I had one on my web site for many years and that page gathered many visits.
Poptronics magazine in July 2001, page 25.
Italian magazine Nuova Elettronica issue 212 dated October 2002
IZ7ATH also published it in QSL.net
Edit: It is not the same circuit. The one I mentioned uses a bridge of four resistors and a single TL084.
« Last Edit: January 10, 2024, 10:40:27 am by soldar »
