Parts list
Quantity Item Supplier Price Total
2 DFRoduino Mega (Arduino Mega) YeRobot £24.00 £48.00
2 MEGA IO EXPANSION SHIELD FOR ARDUINO MEGA V1.1 YeRobot £9.50 £19.00
1 Xbee Explorer Proto-Pic £17.50 £17.50
1 Sparkfun 16x2 Serial LCD Display Proto-Pic £19.50 £19.50
2 Xbee 2mw Series 2.5 Chip Antenna Proto-Pic £20.00 £40.00
5 Pushbuttons Small Red Panel Mount Proto-Pic £0.59 £2.95
5 Hitec Servos HS-322HD Al's Models £7.13 £35.65
2 Servo Extension Leads 200mm Al's Models £2.50 £5.00
2 Servo Extension Leads 500mm Al's Models £2.50 £5.00
2 6v RX Packs Hi-MH+ 2300mAh Vapex Tech £7.50 £15.00
2 TX Pack 9.6v 2100mAh Nimh (SQ) Vapex Tech £10.85 £21.70
2 4.8v - 12v Battery Packs Charger NiMh NiCad Vapex Tech £11.00 £22.00
1 LH68Y ABS Console M8005 Maplins £8.50 £8.50
1 N59FK M/purpose ABS Box D Maplins £4.99 £4.99
3 N98AQ Red Lock Push Switch Maplins £2.39 £7.17
5 Rika Target Changer Target Holder Schießsport Buinger GmbH £14.00 £70.00
1 Various nuts and bolts £5.00 £5.00
1 Wire and solder £5.00 £5.00
1 Small self tapping screws £2.00 £2.00
HTH
Mark
