The first part of this development went well the ac current source is working nicely.
This is the concept:
The right hand side of the circuit is an ac voltmeter. It has to rectify and amplify very small 100kHz signals.
To allow the ESR meter to be used in-circuit, the signal levels have to be kept small at the maximum ESR.
The current source 1.6mA RMS so 1.6mV with a 1
ESR.
This part of the circuit didn't go as smoothly. I will share the experience.
Precision Rectifier
If you Google 'precision rectifier' it won't take very long before this circuit shows up:
The idea behind this circuit is the opamp turns the diode D1 into an ideal diode. That is a diode with no fwd voltage drop.
ImplementationThe opamp circuit was implemented using an opamp built with BJTs:
The circuit was tested and didn't work as well as expected, especially for small signals.
AnalysisThis is a model of the precision rectifier.
Even its very idealized form the circuit doesn't perform well with small signals.
If the diodes are replaced with ideal diodes, the performance improves to:
The trouble is that you can't buy ideal diodes.
OffsetIf input offset is added to the model:
The performance is further degraded:
It seems that the precision rectifier isn't all that precise, especially at small signals, when the circuit is implemented with real components.
(I have a solution that seems to be working well enough. This will be presented in the next installment).
Regards,
Jay_Diddy_B
