I thought that 5V would be more than necessary , that I need to change de 100 resistor to lower this voltage
The bypass capacitor that TIM said 100uf but I presume that I need i lower capacitor, gonna put it on gate right ?
I would omit gate C entirely, initially, and increase the 10k to 100k, it is only there to keep the gate OFF with no drive.
The 100R can increase to 470~1k fine for 100Hz PWM.
My load is a 12/24V motor that can consume almost 2A with 100hz pwm
You may need to check the inrush current,
The package to me is irrelevant I want something cheap and that won't disappear in a few months or years.
Most designs have some dictates around package, as that is determined by how you want to mount it. Are you doing a PCB design for this ? Will you get it assembled ?
Common packages are TO-220, TO-220F, TO-263/D2PAK (the SMD version of TO-220) and DPAK, the smaller SMD brother.
Also common in SMD are SO-8 and compatible footprints.
If you are doing 12 channels, and making volume production, PCB size and time matter, so you might look at Dual Mosfets in SO-8 and compatible flat-pack variants.
eg Diodes inc have DMTH6016LSD variants, in stock at Digikey and Mouser SO-8 < 24mOhm at 4.5Vgs, 60V Dual
