Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Gold plated outline Ground
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Gold plated outline Ground (Read 1401 times)
Nikos A.
Regular Contributor
Country:
on:
January 03, 2019, 08:25:47 am »
Hi everyone and happy new year,
What is the purpose of this outline gold plated ground with vias fence?
Please see the attached picture
Thanks in advance
Nick
Logged
ap
Frequent Contributor
Country:
Re: Gold plated outline Ground
Reply #1 on:
January 03, 2019, 08:40:29 am »
Does not have to be gold plated, but is exposed side area, so here no solder mask, just the board with its plating surface. Purpose of via fence is mostly to keep the EMI generated internally inside the board and not radiate this through the edges.
Logged
Metrology and test gear and other stuff:
www.ab-precision.com
Nikos A.
Regular Contributor
Country:
Reply #2 on:
January 03, 2019, 10:41:46 am »
Thank you for the reply AP,
In that case I suppose that the plating surface is ENIG? (that's why the gold color?)
Logged
deBug
Contributor
Country:
Reply #3 on:
January 03, 2019, 06:38:43 pm »
Yes, looks like ENIG.
Logged
RF enthusiast.
http://www.zachtek.com
German_EE
Super Contributor
Country:
Reply #4 on:
January 03, 2019, 06:51:51 pm »
Both a friend and I normally do this with our home made PCBs, it's a good way to ensure grounding to the case if you use one where the PCB just slots in, or it's a PCB case with the board soldered all the way around. For prototypes you can do the border with copper tape.
Logged
Warren Buffett
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
